Results 1 to 7 of 7
Thread: Seiko Watches
  1. #1
    Mar 2009
    Location
    Seng Kang
    3,222
    24 (100%)
    Default Seiko Watches
    I'll started of with the sumo. The sumo is a JDM(Japan Domestic Model) prospex family lineup in seiko which is not available at most store in Singapore except for shops like superchronos @ Sim Lim Square, Big Times @ Sims Avenue & Sky Watches @ People's Park Complex or you can get it from the Big 3 Japan Online Shops like Seiya,Higuchi or Chino Watch but for this 3 overseas seller,you will need to factor in 7% GST as it's price is over SGD$400.
    The Sumo comes in 3 model standard models and some Limited Edition models which i will not want to touch on.
    The 3 models are : SBDC001 - Black dial black bezel with bracelet, SBDC003 - Blue dial blue bezel with bracelet & SBDC005 - Orange dial with black bezel with rubber strap.
    Price for a new piece will range from around minimum SGD$650 to max SGD$900 depends on which seller you goes to.
    Price for a pre-own piece from what i see at this forum range form Minimum SGD$400 to max SGD$750 depends on the condition and the completeness of the set.
    Technical Specs of the sumo as below.
    Automatic 200M Diver 6R15
    With hack
    +25~-15 seconds/day
    SS case & bracelet
    Curved hardlex
    Index& needle of lumibrite
    Bezel is only anti-clockwise
    Screw locked crown
    thick    13.3mm
    diameter 42.0mm
    SBDC001
    SBDC003
    SBDC005
    累了才放慢脚步; 错了才想到后悔;苦了才懂得满足;伤了 才明白坚强; 醉了才知道难忘 ; 笑了才体会美丽!
    是否我沉默了,你才能听到我的心声 是否我停止了,你才能看到我的眼泪 是否我心碎了,你才会摸到我的心痛 ?是否我消失了,你才会知道我的存 ?
  2. #2
    Mar 2009
    Location
    Seng Kang
    3,222
    24 (100%)
    Next i will talk about is the baby tuna which is in the seiko superior seiko family lineup.
    This series has a total of 7 watch model, 3 are standard model and 4 are limited edition model.
    For this series i will not want to talk about the price as the variants are too much and the prices differ alot for the 7 models which some shops sells thong sia agent set and some sell parallel import set between the J & K model. J model are made in japan for the japan market with kanji datewheel & K model are made in the rest of the world with various datewheel for different country.
    The 7 model are : Standard Model - SRP231,SRP229,SRP 227. Limited Edition Model - SRP453,SRP233,SRP234,SRP236
    The 3 standard model are easily available at most watch shop like city chain,vincent watch,all watches,bencoolen watch shop,chinatown watch shop and Bras Basah watch shop.
    For the Limited edition model, be prepared to pay a slightly higher price than the standard model as it's limited in numbers.
    Below are the specs of the baby tuna.
    Stainless steel case and bracelet.
    Black dial.
    Day and date display.
    Scratch resistant Hardlex crystal.
    24 jewel self-winding Automatic movement.
    Case measures 44mm diameter by 13mm thick.
    Fold over deployment clasp.
    Water resistant to 200 meters.
    3 standard models
    SRP229
    SRP231
    SRP227
    4 Limited edition models.
    SRP236
    SRP234
    SRP233
    SRP453
  3. #3
    Mar 2009
    Location
    Seng Kang
    3,222
    24 (100%)
    Finally I'll go into the Real Seiko Tuna with is consider the real dive watch in the seiko prospex lineup with the rating from a minimum of 300m to the maximum of 1000m depth.
    For the Seiko Tuna, i will not touched on the discon,vintage and limited edition model but will only touch on the standard current production model.
    The current production model will be the quartz model SBBN015,SBBN017 and SBBN013 & the auto emperor tuna SBDX011 which is consider the true king tuna with 8L35 seiko movement and a rating of 1000m with the biggest and thicker case of all tunas.
    The tuna is also a JDM(Japan Domestic Model) prospex family lineup in seiko which is not available at most store in Singapore except for shops like superchronos @ Sim Lim Square, Big Times @ Sims Avenue & Sky Watches @ People's Park Complex or you can get it from the Big 3 Japan Online Shops like Seiya,Higuchi or Chino Watch but for this 3 overseas seller,you will need to factor in 7% GST as it's price is over SGD$400.
    Brand New Price range for SBBN015 & SBBN017 from SGD$1k+
    Brand new price range for SBBN013 from SGD$2k+
    Brand new price range for SDBX011 from SGD$3k+
    Technical specs for SBBN015 & SBBN017 as below.
    300M professional Diver
    Movement 7C46
    Accuracy+/-15seconds/month
    5 years battery
    SS case
    Dual curved hardlex
    Bezel is rotating only one way
    Lumibrite index
    Screw locked crown
    thick 14.7mm
    diameter 45mm
    SBBN017
    SBBN015
    SBBN013
    1000M Professional Diver
    Movement 7c46
    Accuracy +/-15seconds/month
    One peice Titan case
    Bezel Celamix
    Sahhpireglass
    Battery 5 years
    Lumibrite index
    Screw locked crown
    weight    113g
    thick    15.3mm
    diameter  48.0mm
    lug width  22.0mm
    SBBN013
    SBDX011
    1000M Professional Automatic Diver
    Movement 8L35( 26 jewels )
    Accuracy-10-+15seconds /day
    SHIZUKUISHI FACTORY
    Titan one peice case
    Sapphireglass
    Lumibrite index
    Screw locked crown
    weight    140g
    thick     17.1mm
    diameter    48mm
    SBDX011
    hopes all the above helps in clearing up ur doubts and helping u in choosing ur tuna that you wanted.
  4. #4
    Jul 2008
    1,527
    7 (100%)
    Thank you Sifu for the comprehensive detail on
    the Seiko watches....especially the Big tuna
  5. #5
    Jan 2011
    47
    0
    nice collection!
  6. #6
    Dec 2013
    22
    0
    What about grand seiko?
    And place you can get it cheaper?
  7. #7
    Mar 2014
    696
    2 (100%)
    Quote Originally Posted by Markli View Post
    i believe if u dun mind pre-owned then the forum will be a good place to buy it cheaper as the 1st owner absorb the first depreciation.
    For new pieces, i think you can try rakuten.
    Just my 2 cents worth..
Similar Threads
  1. Seiko High End And Seiko Value Watches
    By daytona 6263 in forum Japanese Watch Brands
    Last Post: 11-03-15, 10:42 PM
  2. Maintainece of Seiko watches
    By jflye in forum Japanese Watch Brands
    Last Post: 16-10-13, 11:58 PM
  3. Seiko Watches
    By breitling77 in forum Japanese Watch Brands
    Last Post: 04-05-11, 10:56 AM
