Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: useful tools to help change bracelets/straps
  1. #1
    Jul 2007
    26,251
    65 (100%)
    Thumbs up useful tools to help change bracelets/straps
    for rolex pin holes models, you can use either of the following
    • bergeon 3135
    • bergeon 6767-S
    • generic
    for no pin hole models, i suggest the use of 6767-S
  2. #2
    Jul 2007
    26,251
    65 (100%)
    bergeon 3135
    it comes with a mini-ruler which is useful to measure strap width when need arises
    the pin end construction is not ideal, the original length is abit too long. as such it tends to break easily. however, with the right tools, the broken tip can be grind to a sharp tip again. that is what i did, save some money in purchasing new tips.
    the fork tip groove is deep which makes it easier to work with other watches with leather straps in some cases. the thickness of the fork tip at times work to its disadvantage because it is hard in between the strap and lug of watch.
  3. #3
    Jul 2007
    26,251
    65 (100%)
    bergeon 6767-S
    this tool can be use for rolex pin hole and no pin hole models
    prefer holding 3135 compared to 6767-S which has textured grip.
    the tip ends tend to unscrew itself easily if it is tightened using fingers.
    the fork tip of 6767-S groove is slightly more shallow compared to 3135. it is has thinner tip which makes it easier to get in between tight space between strap and lug.
    it also allows user to work with spring bars of rolex no pin hole models.
  4. #4
    Jul 2007
    26,251
    65 (100%)
    generic tool
    this is a generic tool that is cheaper compared to the bergeon tools.
    it is shorter in overall length compared to the bergeon 3135 and 6767-S, it can be easier to work with for some people.
    the fork tip groove is wider, it is not easy to work with no pin hole rolex models
  5. #5
    Jul 2008
    27
    0
    Bro, I was thinking of buying a bergeon 6825-pf for date just. Is it the rite tool? I'm more confident with plier type tool. If can use, u know where to get it?
  6. #6
    Jul 2007
    26,251
    65 (100%)
    bergeon 6825 allows user to adjust 3 things
    the angle of fork tip
    the length of fork tip
    the tension/width between the fork tips
    too much effort to use.
    would recommend use of 7825 instead if you prefer bergeon brand. it is tweezer style. cost is similar. the advantage of the 7825 over horotec is that the tips are replaceable.
    https://shop.bergeon.ch/Catalogue/Im...mages/7825.jpg
    there is also horotec tweezer that works similar to 7825.
    for bergeon 7825 you can go to khateena at rochor centre.
    Quote Originally Posted by pyro View Post
  7. #7
    Jul 2008
    27
    0
    Thanks for the recommendations! this one will be able to remove datejust bracelet rite? Sorry, newbie here..:-)
  8. #8
    Jul 2007
    26,251
    65 (100%)
    yes, these tools can be used to remove date-just bracelet.
  9. #9
    Jul 2007
    26,251
    65 (100%)
    a picture of 2 common types of spring bar
    the one on top is thick spring bar
    the one below is thin spring bar
  10. #10
    Jul 2007
    26,251
    65 (100%)
    a picture of thin spring bar with 3185
    i would prefer the use of 6767-F with thin spring bar because use 3185, user have to push the tips all the way down to get a grip (reference to the top pic).
    below is a picture of 6767-F with thin spring bar. notice the tips of the 6767-F is a closer fit compared to the 3185
Similar Threads
  1. tag heuer carrera calibre16 Straps & Bracelets?
    By Bond in forum Other Brands
    Last Post: 07-07-11, 08:35 PM
  2. Question: Straps and bracelets
    By trailblazer in forum Serie elegante
    Last Post: 14-12-10, 09:25 AM
