Small air bubble in pam!.
  • Small air bubble in pam!.
    Does anyone have the same problem before?. i have a pam241. Now at the date magnifying glass there`s a small lil air bubble or a small dot which is not at the outer glass... Any advise?.
    Small bubble in Pam!.
    i have a pam241. At the magnifying glass above the date there`s a small dot of air bubble which i cant remove.. and is not on the outer side of the glass anyone can advise?.
      Sent to a watch maker to get it remove.
        Don't panic..............it's a light reflection on the cyclops. it's normal.
          thanks a million!!.. just need to send to any watch maker any they will help u remove?.
            there is nothing to remove, it's an optical illusion caused by reflection of light.
            if you look at it from different angles, the "bubble" will move around the cyclops.
              yes! when u turn and see sometime its not there!. so its normal?. but when i first got it i dont see any. why does it appear now.. is it my eyes or the watch?. haha.. thanks for your help..
                I had a similar issue with my pam88, agree with Leeye, optical reflection on cyclops not water ingestion.
                Certain models have it , certain models dun.
                  I think it is a optical reflection...
                    the "spot" will appear when there is a bright light source (eg. in a room). in an open area you should not see it.
                    why the "spot" appears? it could be due to the lens effect of the cyclops. having studied physics many many years ago, it could be the magnifying effect of the lens. on one hand it helps to magnify the date on the dial, on the other it helps to concentrate light from an external source to a certain point.
                      Ok. I thought it was dust speck in lens. i sibei lousy.
